1999 Gmc Savana air conditioner problem
1999 GMC SAVANA
REILLYTNT
I have a 1999 Gmc Savana Conversion Van. The problem is with the air conditioner. We are getting cold air, and I can hear the blower blowing, but very little air comming out. The fan seems to be running, you can hear it get louder when you change the blower from low to high, and occasionally it will work fine, but intermittently, and seems to be getting more frequent, you cannot feel much air comming out of the vents. The little bit of air comming out is cold. Someone told me it sounds like the vacuum seals gone bad. What do you think? Also, around how much is a fair price for this repair?
Jun 22, 2007 at 3:36 PM
SAVANADENNY
I see your post has been in a while and no responses, I just joined and might shed a little light on the subject.
My 97 Savana has just undergone about $1100 in A/C repairs, and after replacing compressor, fan switch, and misc other parts, still had a similar problem with yours. I took it back and had them check out the system once again, and found a cracked vacuum line hidden under the unbelievable amount of crap under the hood. They fixed that and bingo, full flow. Hope this helps.
Sep 3, 2007 at 11:14 AM
