1998 GMC Savana truck shut off while driving on 95 south
1998 GMC SAVANA
151,000 MILES • V8 • FWD • AUTOMATIC
TONY646
i'm driving a savana3500 box truck. 150 miles into my trip the truck shuts off. i pull over to the right shoulder and crank the ignition but engine would not turnover. i walked over to an auto shop and purchased a fuel filter. when installing the filter i only connected the line that goes to the fuel pump. i then turned the ignition key and fuel did spurt out. fuel pump seems to work. i then connected the other line on the filter, cranked the truck but nothing again. i checked the relay box, all seems well. truck cranks, but engine seems to not get any gas. someone said the problem cold be electrical. any help will be appreciated very much. I'm stuck here in the middle of nowhere hoping to get the truck moving.
Jan 12, 2010 at 11:03 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check for spark? do you have tools? test light? meter?
Jan 12, 2010 at 11:50 AM
TONY646
[quote:c37b2ce397="Docfixit"]Hi
Check for spark? do you have tools? test light? meter?[/quote:c37b2ce397]
i did. also changed ignition coil, but nothing. ended up renting a hotel. tomorrow i'm replacing the distributor module. i'm not getting any sparks. if you have any ideas, please let me know.
Jan 12, 2010 at 4:29 PM
DOCFIXIT
  • 18,828 POSTS
Off line Wed how did it go? if no spark from coil then module likely Auto Zone can test
Jan 14, 2010 at 8:39 AM
TONY646
[quote:487fa1e369="Docfixit"]Off line Wed how did it go? if no spark from coil then module likely Auto Zone can test[/quote:487fa1e369]
thats exactly what it was. the module.
Jan 14, 2010 at 3:27 PM
DOCFIXIT
  • 18,828 POSTS
tony
you done good
Jan 14, 2010 at 3:40 PM
