I'm trying to set the idle on my safari van and was wondering how I can set up a tachometer to it? Thanks.
Apr 8, 2010 at 3:36 PM
DOCFIXIT
CERTIFIED EXPERT
Idle not adjustable is controled by PCM via Idle Speed Controler
Apr 9, 2010 at 11:02 AM
JUSTINF89
MEMBER
What would cause it to idle too low most of the time? Is there a way to hook up a tach anyway?
Apr 9, 2010 at 12:12 PM
DOCFIXIT
CERTIFIED EXPERT
The IAC valve maybe carboned up remove and clean with carb cleaner passageways too. If no check engine light on then carbon likely. Also look for any vacuum leaks. as for TACH not sure check with like Summit see what they have.
Apr 9, 2010 at 2:03 PM
JUSTINF89
MEMBER
Thanks for the help. I will try and clean out the IAC with some carb cleaner or something. May I as where you obtained that picture?
