My 2003 safai's passenger door has dropped slightly and when I try to open the door, parts of the doorlock rub on the stationary post that is holding the door shut. tis binds up the door a bit and makes it hard to open.
I tried to adjust this by loosening the post with a torx and slide it down slightly but I found out that the hole which the post screws into is real tight and does not allow for any up/down adjustment. I was always able to do the adjusting in other vehicles but this one got me .
I could make the hole oblong with a file but I am afraid to unscrew the post completely in fear of dropping the nut down inside of the door frame. Any suggestions??
thanks
thanks
Feb 18, 2009 at 10:27 AM
