I just got the wheels off the ground and here is what I found:
(1) if I put the van in drive, without the engine running, the small gears inside the differential turn along with me turning the right wheel (but not the large gear)
(2) if I put the van in drive, without the engine running, the large gear inside the differential turns along with me turning the drive shaft (but not the small gears)
(3) with the van in park, without the engine running, nothing else turns along with me turning the right wheel (not the even the other wheel) but I can see the end of the shaft turning inside the differential
(4) with the van in park, without the engine running, nothing else turns along with me turning the left wheel (not the even the other wheel) but I hear a scraping sound and I can see the end of the shaft turning inside the differential
(1) when I start the engine and put the van in drive The drive shaft, all the wheels inside the differential and the "right" wheel turn (but not the left).
What does that all tell me.
Jan 12, 2008 at 2:45 PM
