2000 GMC Safari
2000 GMC SAFARI
184,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEANNAS4
VAN SEEMS LIKE IT IS NOT GETTING ANY FUEL. THEN AT TIMES IT DOES. WILL BARELY GO AT OTHER TIMES. HELP
Feb 14, 2010 at 2:03 PM
MUDDUCK272829
[quote:8a0d395cfe="deannas4"]Engine Performance problem
2000 GMC Safari 6 cyl Two Wheel Drive Automatic 184000 miles
VAN SEEMS LIKE IT IS NOT GETTING ANY FUEL. THEN AT TIMES IT DOES. WILL BARELY GO AT OTHER TIMES. HELP[/quote:8a0d395cfe]
Check fuel pressure at the schrader valve. U might be able to see the fuel flow good from the filter but if ure not getting enough to the motor it wont stay running and lack power. 60psi is where it needs to be at. No less. If its lower..check fuel filter by blowing thru it. If its clear then fuel pump is faulty.
Mar 4, 2010 at 2:42 PM
