Heater Core Replacement
REMOVAL PROCEDURE
1. Remove the air cleaner.
2. Drain the engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
3. Remove the heater hoses.
4. Remove the screws that retain the cover to the heater assembly.
5. Remove the screws and the straps that retain the heater core to the heater assembly.
6. Remove the heater core from the vehicle.
There is the instruction's in the diagram number 2 and 3 are the heater hose's you need to remove.Doesn't look like you have to take the dash apart look's like you just have to take the heater box apart in the engine compartment.
Sep 2, 2010 at 12:37 PM
