1998 GMC Safari Fuel System
1998 GMC SAFARI
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEMIKE120
Engine won't start. Voltage at Batt 12.6
Cranks fine ... won't start.
Question: Will code readers register faults for fuel pressure?
I connected ODC II with no stored codes...
I suspect fuel filter or pump...no pump whine when ignition energized....thoughts/comment?
Oh yeah...i swapped the HVAC and fuel relays with no change/effect.
Dec 29, 2008 at 3:41 PM
Test the ECM B fuse and the fuel pump relay
Dec 29, 2008 at 4:11 PM
MIKEMIKE120
ECM B appears good and I swapped the relays with no change.
Is there a fuel pump test port...or do I pull the cover to check fuel in the t.body?
1. My instinct is open "carb" check fuel(vapor).
2. Test spark (plug)
Dec 29, 2008 at 5:39 PM
Do below and tell me what's missing
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 29, 2008 at 6:36 PM
If its a Vortec fuel system-spider its located on the fuel line before it enters the upper plenum.
Jan 5, 2009 at 1:53 PM
