1997 GMC Safari power assit problem
1997 GMC SAFARI
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEIF1956
lost both power brakes/ steering @ same time, no broken belt, no visible signs of leaks, fluids on both are full
Feb 22, 2009 at 9:30 AM
MERLIN2021
  • 17,250 POSTS
If your Safari has the hydraboost brake booster, and the power steering belt is ok, then it's possible the pump shaft snapped, GM had some trouble with PS pumps...remove the belt and check the shaft/pulley.
Feb 22, 2009 at 9:50 AM
