1993 GMC Safari black smoke out tailpipe
1993 GMC SAFARI
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENGINEPRO
Engine starts on clear flood mode...gas pedal alll the way down....wide open throttle.
Engine does not idle well.
Black smoke out the tailpipe.
Thanks
May 24, 2010 at 10:29 PM
Inspect and test the injectors, fuel pressure regulator and coolant temperature sensor.
May 24, 2010 at 10:34 PM
ENGINEPRO
[quote:9161114152="rasmataz"]Inspect and test the injectors, fuel pressure regulator and coolant temperature sensor.[/quote:9161114152] Thanks for your help.
I will check these out in the morning and let you know what is happeneing.
May 24, 2010 at 10:56 PM
