My vehicle cranks over but won't start, was running good right before I turned it off though the check engine light was on. Fifteen minutes later I went to start it up it would crank and start for a few seconds then die. I have replace the fuel pump, fuel filter, fuel pump relay appropriate fuses and oil pressure sending unit, to no avail. There is power going ito the oil sending unit but not ito the relay or the fuel pump. I noticed my check engine light fails to come on when I turn the ignition on.
I am at loss at what to check or do, can anyone help?
Mar 1, 2010 at 9:32 PM
