1989 GMC S15, with hydraulic clutch. I changed clutch, through out bearing (heard it called all kinds of things) so you may call it something else, and pressure plate. Also changed master and slave cylinders and lines. I bled them till I was blue in the face. The clutch arm (fork) moves but not enough. Could the bearing be on the fork the wrong way? I did not take apart just put together. Any help would be appreciated. Thank you
Jan 6, 2009 at 1:04 PM
