1989 GMC S15 1989 GMC S15 Jimmy
1989 GMC S15
SCSAN32
Electrical problem
1989 GMC S15 6 cyl Four Wheel Drive Automatic
i own a 1989 GMC S15 Jimmy and the fuel gauge does'nt work. can i repair this myself and where is the best info on how to do this repair
Oct 6, 2009 at 11:18 PM
HMAC300
  • 48,601 POSTS
you can reppair this yourself if you want to pull the gas tank off. you'll need to see if you are getting power to the guage wire first. If you are , it will be a low voltage blinking light and you grund it and if your gauge goes up then the sender is bad. if it does nothing then the guage is bad. But to replace the sender you'll have to pull the tank to get it out. It's not easy but can be done at home.
Oct 9, 2009 at 10:29 AM
