1988 GMC S15 will not start
1988 GMC S15
71,500 MILES • 4 CYL • 2WD • MANUAL
RON0003
I have put in fuel fiiter, get gas just about new everything .I don't get fire to the fuel injector -I've checked with a noid light but if you spray starter fluid in it it will run for a second then stop
Jun 6, 2009 at 8:32 AM
Do you have power on the red wire on the injector harness connector?
Jun 6, 2009 at 8:57 AM
RON0003
no
Jun 6, 2009 at 10:45 AM
The ECM pin A6 powers the injector thru the red wire, also check the ECM/Ignition fuse
Jun 7, 2009 at 10:07 AM
RON0003
Ignition fuse and all other fuses are Ok
Jun 7, 2009 at 3:24 PM
Either the red wire is open or computer problem.
Jun 7, 2009 at 3:59 PM
