1987 GMC S15 Replacing motor mounts
1987 GMC S15
170,000 MILES • 4 CYL • 2WD • MANUAL
JWADKINS
The nuts that fasten the motor mounts are inaccessible in the frame under the lower a-arm.
These fasteners are turning, which prevents the motor mount bolts from being removed.
How do I get access to these nuts? Does the lower a-arm neetdto be fully removed, or can the a-arm be temporarily lowered to gain access without messing up the front end alignment?
[img:7d7f66975e]http://www.2carpros.com/forum/automotive_pictures/412482_Imgp4044_c_1.jpg[/img:7d7f66975e]
[img:7d7f66975e]http://www.2carpros.com/forum/automotive_pictures/412482_IMGP4045_1.jpg[/img:7d7f66975e]
Sep 22, 2009 at 1:44 PM
You should be able to remove the lower ball joint and gain enough access to it. Please be careful if the coil spring.
Sep 22, 2009 at 10:05 PM
