1987 GMC S15 power loss
1987 GMC S15
WILLMOSS
Transmission problem
1987 GMC S15 6 cyl Four Wheel Drive Manual
i just changed my clutch and now i am having problems with power loss when in gears 3-5 i need help because i have 2 weeks before i have to ship it back to the states from hawaii
Sep 30, 2010 at 6:09 PM
HMAC300
  • 48,601 POSTS
you should have a power loss in all gerars not just 3-5. But stranger thing have happened. check to make sure that you haven't pinched the harness between the trans and block. if not that then check to see if there is a pinched fuel line. If there is replace it as it will cause problems down the road. Also check to see if there are any codes as this may be a coincidence.
Oct 2, 2010 at 8:16 PM
