1986 GMC S15 no compression in all cylinders
1986 GMC S15
265,482 MILES • 6 CYL • 4WD • AUTOMATIC
SISSYPOO1
  • 5 POSTS
nocompression in any cylinders after changing lifters and intake manifold gasket cant find any leaks did run before but made lots of noise from lifters so i changed then now no compression no pressure in crank case or cooling system what did i do
Mar 12, 2010 at 6:46 PM
Hi sissypoo1, Welcome to 2carpros and TY for the donation
id you mike the camshaft lobes before you replace the lifters and also adjust the valve lash?? if all okay-check the valve timing could be off.
Also I recommend you do a cylinder leakage test-if the readings indicates minimum leakage and shows all low compression -recheck your valve timing could a notch or two off-
Mar 12, 2010 at 7:09 PM
