WATER IN ENGINE Cylinder
GMC
EYECE2000
My son overheated My 1996 Chevy Cavalier, 4 cylinder. He put in cold water right away. It would not start. It sat for a week and it started. I notice the water pump weep hole was leaking. So I replaced the Water Pump and thermostat. Fill it coolant, try to start and it did not. Pulled spark plugs and found water in all four cylinders is this head gasket or warped head. If it’s the Head can it be milled down or should I get a new one.
Thanks
Jim
Apr 5, 2006 at 3:20 PM
KENB79764
  • 52 POSTS
take the head to a reputable machine shop and have it checked they may be able to resurface it and they can tell you if it is cracked.
Apr 5, 2006 at 7:13 PM
