Trun signals Not working
GMC
SATRUNSL296
Last night, I found that my right turn signal was not working. Actually, it seemed to be a loose contact. So, I opened the tail light assembly to check the bulb. Now, neither of the turn signals are working. :(
The bulb looked good though loose. Any inputs would be appreciated.
Thanks
SATURN SL2 '96
Feb 2, 2006 at 9:28 AM
CHEVY350GUY
  • 109 POSTS
check flasher. it should be under the dash. make sure there is power at it with key on and turn signal on. if yes replace flasher. if no check fuse. also grease the base of the bulds this will improve stability and contact. let me know if it does not work.
Feb 2, 2006 at 9:59 AM
SATRUNSL296
Thanks chevy350guy.
I shall give it a try and let you know.
Feb 2, 2006 at 10:14 AM
