no spark
GMC
CHRIS WILCZYNSKI
  • 11 POSTS
still waiting for a reply on the 93 cutlass crusier
May 4, 2006 at 8:40 AM
LOSONE
  • 1,616 POSTS
OK, what was the original question? There are only a few moderators and we can't answwer them all.
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
May 4, 2006 at 5:12 PM
CHRIS WILCZYNSKI
  • 11 POSTS
its on on page 2, on the auto repair forum, under no spark
May 4, 2006 at 10:11 PM
LOSONE
  • 1,616 POSTS
Look if you don't have time to re-state the problem I don't go to page two. I do tons of these and I am not on line every day. I am a professional master mechanic who donates my time to help people. If you want me to help you can simplly restate your problem. losone tech level 6
May 5, 2006 at 5:14 PM
CHRIS WILCZYNSKI
  • 11 POSTS
I got a 93 0ld cuttlass crusier 3.3L and theres nothing coming out of plug wires touched to frame while cranking it. car wont start tried new coils, ingmod,plug wires, ecm and wire harness.car still wont run.ohh also repaced crankshaft and reset new comp.put an obd2 on it read out said code 42 ign system problem elec spark timming(est) circuit fault.it also gave a code 34 mass air flow(maf)sensor signal votage is too low. have no clue what to do next any suggestions
May 5, 2006 at 6:05 PM
LOSONE
  • 1,616 POSTS
Hummm I ran into a like problem several years ago on a 93 olds with a 3.1. It turned out the be the connector to the ignition module. I went to a u pull it yard and cut off the connectors and soldered them on. It fired the first time. Are u sure you have a 3.3 and not a 3.1?
There was one other issure I had with a 94 buick. It turned out the plate that the coil packs are mounted on was cause a direct short to the ignition module.
Olds are famous for their ground distribution. You might want to check the bundle of gound wires on the lower left front of the engine. Remove the bolt and clean the connection. Ground goes into the ignition module on the only back/white wire. Try putting a ground on this connection or if you have an ohmmeter check it to graond. You want less than than 2.5 ohms.
Did you replece the crankshsft sensor behind the engine harmonic balancer? That input to the module is on the yellow and purple wires.
My business for over 40 yeasr was automotive electronics. I fixed cars that everyone had given up on.
Let me know
May 6, 2006 at 7:28 AM
CHRIS WILCZYNSKI
  • 11 POSTS
Yeah i replaced the crankshaft sensor, what a job that was, gonna check all grounds, i`ll let you know .Thank you vey much
May 6, 2006 at 3:42 PM
