marker lights
GMC
CATHYMARTY
I have a 1996 chevy cavelier with 61,000 miles on it.Problem is I have 3 marker lights out.
Does anyone know how to get to them to change the bulbs? need to change them asap. inspection due. thanks
May 17, 2006 at 8:29 AM
LSUSSEL
  • 252 POSTS
Yes I have very high knowledge with electrical systems in cars and bulbs. Where are the marker lights located?
May 17, 2006 at 12:18 PM
CATHYMARTY
thanks for the reply,
marker lights are located, front- next to headlight,
back- in the tail light
May 19, 2006 at 9:16 AM
LSUSSEL
  • 252 POSTS
You should be able to get to them in the rear through the trunk, peal back the carpet lining, and if you know how to change the brake lights, they should be right next to the brake lights. peal back where the trunk is, the carpet. or look at the owners manuel and it will tell you how to. as for the font. you might have to open the hood and get it from in there, or go under the car and put your hands up under the bumper. let me know if this helps. and if you need more explaining, reply back.
Lee
May 19, 2006 at 12:37 PM
CATHYMARTY
Thanks Lee,
The back was changed using your advice.
The front was a little of a trick, after using your advice, I came to the conclusion the only other option was to take the headlight out. Well that was the key to the problem.the markers are now all replaced,and ready for inspection.
Thanks a bunch for your help.
Cathy
May 23, 2006 at 8:45 PM
LSUSSEL
  • 252 POSTS
thanks so much for the kind reply. Glad I can be of help. please email me again, if you have any futher problems i might be able to assisit you with.
[email protected]
May 23, 2006 at 9:04 PM
