Intermitten power door lock problem
GMC
SW10475
My power door locks on my 1999 Surburban usuallly work the first or second time by using the door controls or the remote. After that they will not lock or unlock. After sitting for a few hours they will work ok but only once then quit again. The rear doors seem to work ok, the problem is with the other 4 doors. What could be causing this?
May 1, 2006 at 10:21 AM
LOSONE
  • 1,616 POSTS
You may have a lazy door lock relay. It is located high above your emergency brake assembly. It is black, flat and about 3" long. Good luck
May 1, 2006 at 2:33 PM
