How do you know that you Blown a Head Gasket???
GMC
NONDA224
How do you know if you Blown a Head Gasket????? Need your help. Please and thank you!!
Jan 17, 2006 at 1:43 PM
FRANKS45
coolant in the oil looks creamy or oil in the coolant you should be able to see oil on top of the coolant or coolant out the tail pipe may be running hot or over heating
Jan 17, 2006 at 7:13 PM
DARRYL
  • 61 POSTS
Hello: Well head gaskets can fail in several ways. One failure is that the oil passage and water passage can get hooked together, then oil gets into the water and water gets into the oil. The oil will usually change colors, get sort of white looking, thats bad. Matbe will see oil slick signs where the water is poured into the radiator. Another way is a cylinder leak into the water jacket. Depending on the nature of the failure it may act like a one way valve, Only compression into the water, but water not into the cylinder. If you have this type of failure usually the enging will get hot quick and be difficult to keep it cool no matter what you do. By removing the radiator cap and keepong it topped off with a hose running slowly watch for air bubbles coming out of the radiator. This is pecause the leaking cylinder is pushing air into the water jacket. Sometimes a compression check will show the faulty cylinder if it is a cylinder seal type failure. A water jacket to oil gallery failure a compression check will not show that failure. There are several other tests that can help determine, but those are the easiest
good luck
Darryl..
Jan 18, 2006 at 9:26 PM
NONDA224
Thanks for all your help, but I think that it is time to say good bye to that Car. Not only was all that going on but now just found out that the strutts are bad. (Hoped I spelled that right......lol) Time for a new car, I hope that it can last till then........lol.
Michelle.
Jan 19, 2006 at 5:54 PM
