Heat and Air Conditiong
GMC
GILMORE GIRLS
2003 Saturn Ion 3 29000 miles
I am having troule getting heat and air conditioning to come out of the vents? What could be the problem? Would it be covered under by warranty?
Thank You.
Apr 10, 2006 at 5:13 PM
LOSONE
  • 1,616 POSTS
The problem is vacuum isn't getting to the controls correctly or the control is defective. Check under the hood for a small 1/8" black plastic line that leads from the engine into the car in a wiring harness. The end of the lne should be connected to a vacuum source. Often the break due to heat.
Warranty?? It shoild be depending on the in service date. 3 Years and 36K
Good luck
Apr 10, 2006 at 5:26 PM
