[quote:3dbad17c40="debhicks"]1999 GMC sieraa truck. 105,000 miles. The headlights stay on when the ignition key is on. Not the DRLs[/quote:3dbad17c40]
Sounds like something is keeping the Headlamp relay closed. Could be a bad relay stuck closed. The two inputs are from the Body control Module, but that should loose power when the ignition switch is off. The other is the Headlamp and Panel Dimmer switch. This is always hot. Remove your relay from the Underhood Bussed Electricl centor, and test it out. This diagram is hard to read, but the pin numbers should be 30, 35, 36, and 37? Anyway, pin 30 and 37 should be open with the relay out. If they show continuity, then the relay is stuck closed and needs to be replaced.
Now, if that leg of the relay is open, then check pin 35 for power. If it has power, I would suspect the light switch in the truck as being bad keeping the relay powered.
Good luck and let us know what fixed it.
Jul 31, 2006 at 4:10 PM
