Headlight Diagram
GMC
BIGDOGS63074
I have a chevy trailblazer 03 with 82566 miles and i have a headlight that is out. I am unable to figure out on how to replace the burnt out bulb. if you have a diagram. or whatever id appreciate it.
May 1, 2006 at 4:03 PM
BURRBRIAN
  • 158 POSTS
Well, if the setup is close from your's to mine, 99 Silverado,
you can pull 2 pins that hold light housing in, taking it loose and then the bulb socket shoud be a twist out type. Be careful about getting the new bulb dirty or a lot of skin oil on it as this causes them to burn out fairly quick for some reason. Hope this helps you out. :roll:
May 1, 2006 at 7:16 PM
