2001 GMC, 45000 miles, 5.3 engine.
I would like to change the filter and oil in my transmission. It appears to have a sort of drain plug on the pan. This plug has a recess, that would not let the pan drain all the oil, but it would get most of it. Is this a drain plug?
Also I noticed that a couple of allen socket screws hold the linkage on the side. This looks like it will have to be lowered/unattached. Is this a part of the method to remove the pan?
Next question is can you comment on how much fluid I will need to replace what I drain out.
This is one of the automatic trannys that you can not drain all the oil. Bummer to me. I wish the builder would go back to a set of plugs that would allow a person to drain all the oil.
TIA, :)
TIA, :)
Mar 17, 2007 at 1:20 PM
