driver headlight low beam not working
GMC
DRAGON
hello, 99 chevy trailblazer (has S-10 body) only driverside headlight (low beam) does not turn on. I have replaced the bulb socket, it came on for a second then went off just as fast. Manual switch doesn't turn it on either. Thanks for your help.
Jan 19, 2006 at 10:16 AM
SC1 RACING
  • 117 POSTS
did you touch the bulb? if so it will blow from the oil in your skin, also check the socket. if corroded it will short across. if it is corroded get some diode greese and install
Jan 20, 2006 at 1:10 PM
