my '97 cavalier coupe has no dashlight function, nor can i use the interior light control. the interior light does come on when you open the door and go out after a timed interval. also, when you turn the headlights on the radio display goes dim so it can barely be seen. and a newer problem, both my blinkers are blinking too fast when in use. we've checked the fuses and they are fine, no replacements needed. what else can i check to find the root of these problems? i have to get this car fixed in order to pass safety inspections.
Jan 11, 2006 at 6:58 PM
