Chevy Truck Electrical Problem
GMC
WINDDILLA
  • 7 POSTS
I have a 99 Silverado 5.3L
I'm having problems with the battery discharging until dead. I have replaced the battery and alternator twice in the last 2 months. I have re-charged the battery and the vehicle will start, but instantly the powerdrain begins and within 5 min the truck dies. The alternator is putting out 14 volts. I placed a scanner on it and it shows a diagnostic code of
( alternator L terminal ckt ) My tester is able to test whatever this code is but my truck evidently is not able too or is not programmed to provide such a test. I've spent alot of time looking over all the wiring for shorts or grounds and everything look good and tight. I can put my multimeter on the battery with the vehicle shut off and you can see the voltage slowly drop. Any suggestions would be greatly appreciated.
Kind Regards~
Feb 15, 2006 at 2:47 PM
FISHERMAN
  • 937 POSTS
5 minutes? thats fast!
you dont have a short circuit because the battery will burn the wires right away!
its got a be a resistor device.. such a motor or light ....
..5 minutes!!!
Feb 15, 2006 at 3:25 PM
WINDDILLA
  • 7 POSTS
5min with battery I just purchased about a month ago. I've had to recharge it twice. It'll have to be replaced again.
Feb 15, 2006 at 4:14 PM
