I have a 97 cavalier, and I just recently found out I had a small hole in my gasket. My #4 cylinder was also misfiring. As a last resort before an $800.00 bill, I decided to try K&W block seal. I followed the directions carefully, then refilled with antifreeze/water as directed. The check engine light has turned off and the engine no longer misfires. The engine also sounds normal again. But the heater wont blow hot air and the car still over heats. If the K&W clogged the heater core hoses or heater core itself, could it be causing the over heating and cold air?
Mar 24, 2006 at 8:01 PM
