1998 Other GMC Models startsup and dies
1998 GMC
SAB10047
Engine Mechanical problem
1998 Other GMC Models 6 cyl Two Wheel Drive Automatic
what is wrong? The gas filter was taking off and blow through could it now be the fuel pump?
Jan 12, 2010 at 9:10 PM
MICKEY-D
  • 304 POSTS
Just because you can blow through the fuel filter, does not mean it's good. You also need to check the fuel pressure at the fuel rail. you could have a weak pump, bad pres. regulator, or a bad pump relay.
Jan 17, 2010 at 8:02 PM
