1997 Other GMC Models power steering but i have brake line r
1997 GMC
CHEVYMAN513
Steering problem
1997 Other GMC Models V8 Two Wheel Drive
a brake line from the master cyln running to my power steering box appears to be leaking but i lose power steering fluid to
May 13, 2008 at 3:55 PM
MERLIN2021
  • 17,250 POSTS
OK that's not a brake line, it's the brake hydraboost line run off your power steering pump, DO NOT MIX the two typres of fluid! Brake system will be destroyed! Just replace that hydraulic line to the booster and bleed it...turn the wheel all the way a few times while checking the fluid in the power steering pump. Do not keep wheel forced at the stop! Do not allow power steering pump to run dry!
May 13, 2008 at 4:00 PM
CHEVYMAN513
so a boost line for the power steering does run through the brakes master cyln but the fluids dont mix ?
May 13, 2008 at 4:12 PM
MERLIN2021
  • 17,250 POSTS
NO the line goes to the hydraboost, powered by your powerer steering pump, not your brakes...it is the powerer assist for your brakes, not your brakes.
May 14, 2008 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_HydraBoost_1.jpg
Does your look like this?
May 14, 2008 at 2:06 PM
