High Idle
GMC JIMMY
MJWIDD
  • 12 POSTS
1988 Gmc Jimmy 4x4
At start up idle races, then when engine should be warm enough it comes down but not a lot. Does anyone know if there is an idle adjustment screw. it's a 2.8L 6 cyl. engine..................Also I thought i would install aftermarket gauges when I removed the temperature sensor and installed the new one the truck wouldn't even start in the morning. When i switched it back I noticed the idle would come down if I unhooked the sensor plug. Any Ideas????????????
Jan 19, 2006 at 8:04 PM
FIZZAK
  • 15 POSTS
IAC valve on the TBI unit. (Idle Air Control)(Throttle Body Injection) Common issue and is easy to replace.
Thats my guess..
Jan 20, 2006 at 10:11 AM
DARRYL
  • 61 POSTS
hello: The coolant temp sensor for the ECM will control idle speed when cold until gets warm. Works just like a choke. As the Engine warms the idle speed will come down. Idle speed is controlled mainly by the IAC motor. Also could be a cracked vacuum hose somewhere, or possibly fell off. Bad coolant temp sensor can cause problems with idle and all other RPM ranges
good luck
Darryl..
Jan 23, 2006 at 6:01 PM
