2001 GMC Jimmy noise vibration
2001 GMC JIMMY
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
WGREGGG3
my car seems like make a noise almost like something is rubbing the tires but as I reach higher speeds like on the highway the noise turns to a very loud hum and the steering wheel shakes a little bit and vibrates
Jun 2, 2010 at 2:56 PM
HMAC300
  • 48,601 POSTS
have a pro check your front wheel bearings, axles and front end. You may have a wheel bearing going bad. Or worse yet an axle shaft.
Jun 3, 2010 at 3:17 PM
