2001 GMC Jimmy no gauges & tail lights
2001 GMC JIMMY
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICKDOT2
the gauges & tail lights quit working all of a sudden, but vehicle still starts & runs
May 23, 2009 at 9:27 AM
JDL
  • 16,098 POSTS
Hello, I'd start by checking the parks lamp fuse, 20 amp, in the underhood fuse box. The fuse may have a bare spot over each leg, so you can check for voltage, using a testlite, or you can pull the fuse, check for voltage at the fuse terminals.
May 23, 2009 at 10:53 AM
RICKDOT2
Already checked fuses inder hood & left side of dash
May 23, 2009 at 7:18 PM
JDL
  • 16,098 POSTS
Just to be clear, did you check for voltage at the fuse circuit? If so, check the wiring at the headlamp switch.
Orange wire is feed to the switch, should be hot all the time. Lt blue wire from the switch is for dash lites and tail. that wire should be hot when you activate the switch.
May 24, 2009 at 9:28 AM
