2001 GMC Jimmy Ignition problem?
2001 GMC JIMMY
BILL POLLARD
Electrical problem
2001 GMC Jimmy 6 cyl Two Wheel Drive Automatic
Was driving on the interstate turned onto an exit ramp, (clover Leaf Style) truck stopped running half way up ramp, battery died, it was dark outside, had truck towed to house; put battery on charger, reinstalled battery in truck, now i can not get the ignition to unlock, or turn on, to either the accesory or to the run/ start mode... it's almost like the key doesn't work anymore; what's going on? i need to get this running so i can go to work on monday; have you ever seen this before?
Apr 18, 2010 at 4:12 PM
Inspect and test the brake switch if okay have the shift interlock control system checked out-
Apr 20, 2010 at 3:31 PM
