2001 GMC JIMMY 4.3l
My jimmy has high oil pressure which in return keeps blowing the seal on the oil filter I figured it was a clog so I used engine flush and while doing the flush it brought the pressure back down to 40psi so I then drained and filled it with oil and new filter and same thing happened I have repeated this procedure 3 time and it still is blowing the seal. I also have removed and flushed all oil line up to the block any Ideas on what is going on?
Mar 28, 2010 at 9:35 AM
