2001 GMC Jimmy fuel pump,sending unit
2001 GMC JIMMY
LITTLEHORSE
Electrical problem
2001 GMC Jimmy 6 cyl Four Wheel Drive Automatic 160K miles
do i have too drop the gas tank too locate it.
Mar 2, 2010 at 2:27 PM
JDL
  • 16,098 POSTS
Hi, just my opinion, if you suspect a fuel issue, I'd use a fuel pressure gage, first. Around here some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Next, I'd want to check good voltage and ground, at the pump connector, proper terminals, engine cranking. You need to drop the tank to replace pump,if pump is the problem?
Mar 2, 2010 at 2:40 PM
