2000 Jimmy 6 cly ............ball joints
2000 GMC JIMMY
IRONGUTS
I have to replace the upper ball joints on my 2000 Blazer and was wondering if any special tools are required to do the uppers.......and what is the basic procedure.....tia
Answer:
I guess I will have to answer my own question since I already did it....
first jack up the front end and take the front tire off, support the lower arm with a jack or jack stand. Then unbolt the brake line clip. Remove the cotter pin and slacken the ball joint nut. Now my ball joints were factory rivetted so I had to grind the rivets off using a mini grinder and punch the rivets through. Old ball joint should come right out.
Install new bolt-on ball joint . Then install main nut with cotter pin. Rebolt on brake line clip. Grease new ball joint nipple and any others if you wish. Install tire and remove jacks. Should take about an hour!
Aug 30, 2007 at 10:55 PM
SERVICE WRITER
  • 9,123 POSTS
Thanks for the update, someone facing this will appreciate it. We are obviously bogged down with posts but working on catching up.
Sep 11, 2007 at 7:53 AM
