will the motor,transmission,transfer case,and all the wiring harness from a 2000 jimmy with a 4.3 vortec go into a 1998 chevy balzer?
Jul 26, 2010 at 1:31 PM
HMAC300
CERTIFIED EXPERT
if the blazer is 4 wheel drive it will and has the same harness although you may have problems installing the harness due to model year changes. you are better off to use the same set up in the 98 instead of usin gthe newer harness.
