2000 GMC Jimmy reinstalling the dash and radio
2000 GMC JIMMY
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
MOLEDOGGY
I just changed out my heater core/ While replacing the dash and radio, i seem to be missing a radio cable. there are female plugs on the back of the radio and i can only find 1 male plug for it. everythingelse in present for the rest of the dasn connections. a friend helped me remove the dash and unpluged the radio, so i didn't see what was connected at the beginning. i plug is a 4 gang plug and the other is a 9 pin. and thoughts?
Well, I put it together with the 9 pin empty and everything works just fine. I guess it's for add-on's.
Thanks anyway.
Oct 18, 2009 at 12:05 PM
RACEFAN966
  • 5,029 POSTS
Ok here is what I found. There is a couple of different options depending on weather or not you have a factory amp. But for most part here is the plug that should have gone into the back of the radio.
https://www.2carpros.com/forum/automotive_pictures/249564_gm20plug_1.jpg
Oct 20, 2009 at 10:23 AM
