2000 GMC Jimmy preventitive maintenance
2000 GMC JIMMY
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
T4ERICKSON
In the past few years I've had problems with wheel bearings (among many other things). I was wondering if you could give me an overview of the significance of the bearings and what can I do as preventive maintenance. Thanks.
May 6, 2009 at 6:47 PM
2CARPRO JACK
  • 11,533 POSTS
Those are sealed hubs, there isnt much you can do for them as far as maintenance goes,If you are running wider/ bigger tires than stock it will wear them out a little faster.Using a high quality replacement will help too. Not a real good design, they fail often so dont feel all alone on this issue
May 7, 2009 at 8:05 AM
