I've recently began have issues with my Jimmy. It first appeared whan I lost all power the was diagnosed as a bad battery cable. That was replaced and the next day the battery was low so I jumped the truck to get it running. Installed a new battery. The next time I went to start it the battery was fine and truck wouldn't start. That was diag as a bad starter. I replaced the starter yesterday and everything seemed fine about twenty minutes when I went back outside I heard a loud clicking that sounded like the starter soliniod engaging over and over. This is probably what burned out the starter and drained the battery in the first place. Could this be a bad ignition switch or bad relay? Or worse?
Feb 18, 2007 at 10:06 AM
