[quote:b49a10dc37="philipminer"]Engine Cooling problem
2000 GMC Jimmy 6 cyl Four Wheel Drive Automatic 147000 miles
Just rodded and rebuilt the radiator and will be putting in 50/50 mix of the green stuff. I have not used the Dex-Cool for several years. Is there a significant benefit to flushing the system with cleaners, such as Prestone Super Radiator Cleaner? I used the above cleaner and flushed the system about two years ago. I did not get the two years or 50,000 miles on the coolant. How long can I expect coolant to last.
Thanks,
Phil Miner[/quote:b49a10dc37]
Phil,
I am the tech manager at Prestone. You should remove your thermostat, fill the cooling system with water and super flush. Drive the car for at least an hour and then thoroughly flush the system. You should not be using the "old green" coolant. It contians silicates and the water pump seal in your vehicle can and will eventually be harmed by the silicates. you should be using a long life OAT based coolant. if your dex-cool adverse ( you really shouldnt be, most all automakers are going to it in 2011), you can use Prestone long life coolant, mix with distilled or deionized water at a 50/50 mixture and you will not need cooling system service for the next 5 years.
Oct 1, 2010 at 8:52 AM
