2000 GMC Jimmy ABS system
2000 GMC JIMMY
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
DABECKER1975
My abs light is not on but system becomes active at slow speed stop on dry pavement. I have replace both front bearings and sensors, bearings were bad.
since then the abs is active when stopping.
Aug 30, 2009 at 10:38 AM
Recheck your work. It sounds like a fire is shorted on one of the sensors, or a sensor isn't picking up a signal. Check for dirt, damaged wiring, and make sure the connector is tight and clean.
Sep 5, 2009 at 10:44 PM
