1999 GMC Jimmy outside temp readout
1999 GMC JIMMY
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
LINCDRYWALL
the outside temp readout in the driver info system on the roof console is not reading corectly and ive look in the haynes and chilton and can not find out where the sensor is located can you help me thanks
Jan 31, 2008 at 1:22 PM
BILLYBOBASAN
  • 13 POSTS
Every GM vehicle I have worked on the sensor is behind the grill in front of condensor/radiator,sometimes near center & sometimes near left side headlight assembly. It should have 2 wires going to it. When you unplug it readout inside vehicle should change. If it does you know wiring is ok!
Good luck .
Jan 31, 2008 at 2:14 PM
