1999 GMC Jimmy has a miss
1999 GMC JIMMY
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGDAVE
I changed the fuel pump, it ran rough, so I replaced the sensor with the original, no change, a mechanic sprayed around the manifold gasket looking for bubble, non found but he said this was the problem, he said he could hear a change in the engine when he sprayed the brake cleaner aroudn the gasket, I didnt hear anything, the truck ran perfectly before the fuel pump change, my way of thinking is somehting to do with the fuel pump?
Dec 5, 2008 at 10:25 AM
DOCFIXIT
  • 18,828 POSTS
Why did you change pump? old one fail? may have introduced some debris into fuel system hampering injector operation.
Dec 6, 2008 at 4:13 PM
