1999 GMC Jimmy driver door latch
1999 GMC JIMMY
C3LOTTI
Interior problem
1999 GMC Jimmy 6 cyl Four Wheel Drive Automatic 99k miles
the latch is locked in the down position it strikes the door frame latch bar and i cant close the door. how do i get access to the outside door handle control rods that connect to latch assembly to disconnect them to remove latch help please!!
chris[img:240e6d6dd1]http://www.2carpros.com/forum/automotive_pictures/275583_door_1.jpg[/img:240e6d6dd1]
[img:240e6d6dd1]http://www.2carpros.com/forum/automotive_pictures/275583_latch_2_1.jpg[/img:240e6d6dd1]
Nov 23, 2008 at 5:37 PM
SWILLIAMS
  • 597 POSTS
Try the easy way first. Stick a screwdriver into the latch and then hold up the handle while pulling the latch open with the driver.
In your close up of the latch you would put the screwdriver in the left hand opening in the latch, Then while lifting the handle you would pull the screwdriver to the right.
What you're doing is making the screwdriver act like the striker itself and rotating the latch cam.
The probable failure in the latch is DIRT. They get dust and crud in them and the small spring that pulls the latch clip down sticks, Then it only takes a small tap to rotate the latch in.
Now in the event that you already tried that and the latch still didn't move the latch comes out without much trouble. Reach in the hole at the bottom of the door and find the latch. The clips on the rods just unlock from the rods by pushing them off the rod. Then the rod slips out of the clips. the latch then slides down the door to the bottom and out the hole.
Nov 25, 2008 at 9:26 PM
