how can you reset the outside temperature gauge? My gauges seems to be reading about 40 degrees high.
Jun 24, 2009 at 9:56 AM
SWILLIAMS
CERTIFIED EXPERT
It is self calibrating. If it always reads wrong the sensor has probably failed. There is a test procedure but you need the factory book to get it.
Jun 24, 2009 at 11:22 PM
LMAC
MEMBER
Generally whats involved to replace the gauge and whats the cost?
Just trying to see if its worth the exopense.
thanks for your input.
Jul 1, 2009 at 10:16 AM
SWILLIAMS
CERTIFIED EXPERT
The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.
Jul 2, 2009 at 9:30 AM
LMAC
MEMBER
[quote:6cfee7f336="SWilliams"]The sensor is a simple plug in part located behind the grill . The wiring runs just under the upper edge of the radiator support and across to the sensor.[/quote:6cfee7f336]
